Is the fly-through feature only available in Bentley Map Enterprise? I am currently evaluating both software and only see the Utilities>Render option in Enterprise.
Hello,The FlyThrough tool is available under two editions of Bentley Map: Enterprise and Map for MicroStationThe file must be a 3D DGN file.Key-in: MDL LOAD FLYTHRU
I hope that helps.Sebastien Lefrancois
Hello Ben,
You can find a list of the Features offered in each of the different Bentley Map Editions in the Read Me file. I've created a link that will take you directly to this document online:
https://docs.bentley.com/LiveContent/content/en/Bentley%20Map%20Readme-v1#docid=GUID-931493EB-DD5C-4A41-8E99-C145BFC96F8B&addHistory=true&query=&scope=&tid=&filename=GUID-931493EB-DD5C-4A41-8E99-C145BFC96F8B.xml&resource=&inner_id=&toc=false&eventType=lcContent.loadDocGUID-931493EB-DD5C-4A41-8E99-C145BFC96F8B
