Can someone here please confirm that Terrasolid software is compatible with Bentley Map Enterprise? Using BM Enterprise V8i (SELECTseries 4), Version 08.11.08.864
Thank you.
Ben
Looking at the Terra Solid site, they list earlier versions. Is your configuration not initializing properly? If not it may depend on the edition you are using, Standalone vs. For MicroStation?
Bentley products (tested version numbers)
MicroStation V8i (SELECTseries 3: 08.11.09.292, 08.11.09.357) MicroStation V8i (SELECTseries 2: 08.11.07.443) MicroStation V8 (2004 Edition: 08.05.xxx) Map, Map PowerView (08.11.07.425, 08.11.09.91) PowerCivil (08.11.07.428, 08.11.07.494)
Thank you for the response.
I haven't install Terrasolid yet. I just wanted to make sure it will work before I purchase it. I'm about to download a trial version now.
