Hello all,
i try to load dynamically xwms file and i can't find any Keyin on Configuration variable to do this.
Thanks.
as example:
active level "WMS";$ raster attach fixed "$(USER_WMS_DIR)\\Kataster\\Kataster.xwms";raster dialog open raster_manager
Answer Verified By: Nikolay Tsonev
Hi, Miro,
is there any keyin for Microstation CE (the same task) ? For V8i woks fine, but CE has a problem with file format:
Can you help me please?
I suggest to create a new Xwms file. Keyins as deciribed above by Miroslav still work.E.g. with raster attach fixed "spoorwegen.xwms" the Xwms file is attached that is located in a folder pointed by ms_rfdir.
