I am running Bentley PowerCivil and have read multiple posts about activating Bentley Map unfortunately, when I go to Tools>ActivateMap, it does not show up. Can anyone help me with this?
What version of PowerCivil are you running? If it's an older version it may not have Map included.
I don't have PowerCivil, but I know that between InRoads, GEOPAK, and the Power versions of those the Active Map tool is in different locations. It could be under the Utilities menu, or under a sub menu named Applications, Add-Ons, or something similar.
Rod WingSenior Systems Analyst
We are running powercivil V8i (SS4) for North America
Bentley Map is not included with all of the Civil Engineering products. This post lists the civil products that Map is delivered with. PowerCivil is not included in that list.
- InRoads
- InRoads Suite
- Rail Track
- Rail Track Suite
- Power InRoads
- Power Civil for [Country] (not including Power Civil for North America)
- Power Rail Track
- MXROAD
- GEOPAK Civil Engineering Suite
- Power GEOPAK
Dan, thanks for pointing that out. I looked at that post and breezed right over it not being included with North America)
Sure Tim, no problem. I understand it can be confusing. I've had to refer back to that list for a long time. It would be simpler if 'the powers that be' included it in all-or-none sometimes...
