Trying to enable survey tools in Map SS4. Help file describes the following:
The process does not appear to be working. Here is the issue:
Any ideas?
Cliff
Hello Cliff!
You must add a space between the full path and the variable, as it shown in the help file you screen captured. In order, it need to run the application then activate the variable defined.
I hope that helps.
Sebastien
Answer Verified By: cliff
Sebastien,
Thank you that was the trick! I now have Project Explorer with the Survey tab enabled.
