I have several levels which automatically appear in any new .dgn file that I create. These did not appear when we used to use Descartes but since switching to Bentley Map they are in the level manager in every new file. The problem is that I cannot delete them. The levels are unused, and are apparently related to the LineStyle.dgnlib. However when I try to detach a library the message center tells me that there are no libraries to detach. Under configuration Level Library Path the folder listed does not contain any .dgnlib files. Additionally a search of my entire C drive has not located any linestyles.dgnlib file.
Does anyone know of any way that I can remove these unused layers?
Hi Brandy,
These are indeed levels in the DGNLIB. When you open the .dgnlib file itself you can delete the levels. Use Windows Explorer and search for it in your product Workspace path, such as: C:\ProgramData\Bentley\MapStandalone V8i\08.11.09.864\WorkSpace\Projects\Examples\Geospatial\defaults\dgnlib
