I have defined, in Geospatial Administrator, a linestring feature. But I want to create/draw it in a special way. I have written my own MDL command supporting drawing orthogonal buildings process. And now I'd like to combine standard feature creating tool with this command. In other words, the result I need is to have a command that creates a feature drawn using my MDL function. Where should I call this command?
Myzzard
Hello Myzzard,
Here is a code snippet that I added to the GasMain MDL example to automatically annotate the feature after placement if the AutoAttribute system property is TRUE. This system property setting is available in the Feature pulldown menu.
Public void placeGasMain_secondPoint ( Dpoint3d *pntP, int view ) { BoolInt autoAttribute = FALSE; generateGasMain (pntP, view); xfmFeature_write (gasMainFeature, FALSE); xfmFeature_savePreferenceProperties (gasMainFeature, L"placing"); // If auto-attributing after placement is on then activate Annotate method (if it exists) xfmPropMgr_getPropertyBoolValue (&autoAttribute, L"SysProps/AutoAttribute", FALSE); if (autoAttribute) { BoolInt annotateMethodExists=FALSE; xfmCmdMgr_methodExists (&annotateMethodExists, L"GasMain", L"Annotate"); if (!annotateMethodExists) { placeGasMain_done(); return; } // --- set group to edit as required by annotate logic --- xfmFeature_setFeatureGroup (gasMainFeature, L"edit"); // Since not opening edit box, initialize "editing" properties in case required for annotation xfmFeature_initializeProperties (gasMainFeature, L"editing"); // --- set locatedFeatureRootName which is required by edit logic --- xfmCmdMgr_setProperty (L"locatedFeatureRootName", L"GasMain"); xfmCmdMgr_setProperty (L"locatedFeatureGroupName", L"edit"); // --- start up the feature's Annotate Method --- xfmCmdMgr_activateMethod (L"GasMain", L"Annotate"); return; } placeGasMain_done(); }
Dpoint3d *pntP,
int view
if (autoAttribute)
return;
Also of interest is this snippet from the XFM Standard Operations Library which will open the edit dialog box before annotation if system properties are set to do so.
/* If "SysProps/AutoAttribute" == TRUE If "SysProps/OpenEditDialogDuringAutoAttribution" == FALSE start annotation placement (run "Annotate" method) Else open Edit box (run "Edit" method) Else restart current XFM command (placement) */ xfmPropMgr_getPropertyBoolValue (&autoAttribute, L"SysProps/AutoAttribute", FALSE); if (autoAttribute) { MSWChar* featureName=NULL; MSWChar* featureAlias=NULL; xfmCmdMgr_getProperty (&featureName, L"placementFeature"); xfmCmdMgr_getProperty (&featureAlias, L"placementAlias"); BoolInt annotateMethodExists=FALSE; xfmCmdMgr_methodExists (&annotateMethodExists, featureName, L"Annotate"); BoolInt openEditBox = TRUE; xfmPropMgr_getPropertyBoolValue (&openEditBox, L"SysProps/OpenEditDialogDuringAutoAttribution", FALSE); if (openEditBox) { // --- check for Edit and Annotate Methods for current feature --- BoolInt editMethodExists=FALSE; xfmCmdMgr_methodExists (&editMethodExists, featureName, L"Edit"); if (annotateMethodExists && editMethodExists) { XfmFeatureP editFeature=NULL; if (SUCCESS == xfmFeatureMgr_loadFeatureFromList (&editFeature, placementGroup, featureAlias)) { // --- set group to edit as required by edit logic --- xfmFeature_setFeatureGroup (editFeature, L"edit"); // --- set locatedFeatureRootName which is required by edit logic --- xfmCmdMgr_setProperty (L"locatedFeatureRootName", featureAlias); xfmCmdMgr_setProperty (L"locatedFeatureGroupName", L"edit"); // --- start up the feature's Edit Method --- xfmCmdMgr_activateMethod (featureName, L"Edit"); if (NULL != featureOps) dlmSystem_mdlFree (featureOps); if (NULL != placementGroup) dlmSystem_mdlFree (placementGroup); if (NULL != featureName) dlmSystem_mdlFree (featureName); if (NULL != featureAlias) dlmSystem_mdlFree (featureAlias); if (NULL != editFeature) xfmFeature_free (&editFeature); return; } if (NULL != editFeature) xfmFeature_free (&editFeature); } } else { if (annotateMethodExists) { XfmFeatureP editFeature=NULL; if (SUCCESS == xfmFeatureMgr_loadFeatureFromList (&editFeature, placementGroup, featureAlias)) { // --- set group to edit as required by annotate logic --- xfmFeature_setFeatureGroup (editFeature, L"edit"); // Since not opening edit box, initialize "editing" properties in case required for annotation xfmFeature_initializeProperties (editFeature, L"editing"); // --- set locatedFeatureRootName which is required by edit logic --- xfmCmdMgr_setProperty (L"locatedFeatureRootName", featureAlias); xfmCmdMgr_setProperty (L"locatedFeatureGroupName", L"edit"); // --- start up the feature's Annotate Method --- xfmCmdMgr_activateMethod (featureName, L"Annotate"); if (NULL != featureOps) dlmSystem_mdlFree (featureOps); if (NULL != placementGroup) dlmSystem_mdlFree (placementGroup); if (NULL != featureName) dlmSystem_mdlFree (featureName); if (NULL != featureAlias) dlmSystem_mdlFree (featureAlias); if (NULL != editFeature) xfmFeature_free (&editFeature); return; } if (NULL != editFeature) xfmFeature_free (&editFeature); } } if (NULL != featureName) dlmSystem_mdlFree (featureName); if (NULL != featureAlias) dlmSystem_mdlFree (featureAlias); }
Else
if (openEditBox)
else
Chris
