It appears the Personal Share function is being phased out in favor of ProjectWise.
Anybody tried using OneDrive to overcome this issue?
Cliff
I believe you can use the "Open with..." option in apps like OneDrive and DropBox to initialize the file you would like to open in Bentley Map Mobile. I'll verify that and let you know more.
Hello Dan. Here is where I'm at:
1. I tried OneDrive. Can't figure out how to add applications to the Open with menu. I'm using an Ipad.
2. So far Google drive has worked. For whatever reason Map is in the open with menu.
I also downloaded Navigator and Project Wise explorer. These don't seem to recognize my project in Project Wise Share.
Any ideas?
Cliff have you tried using ProjectWise Share and its not working? Can you give me some idea about the apps and versions you're using?
Hello Sam
Yes we are using PW Share. No it's not working. There appears to be version conflicts between PW and the i-models published from Bentley Map. I believe the folks on the PW team are working to resolve this issue. Dan has been great working to help fix the issue.
