Good morning,
I have been working with MicroStation (Geopak, PowerSurvey, OpenRoads) for a while. I have moved to a new section in Cartography and started working in ArcGIS Pro, but do not like the tools.
I need help getting started in Bentley Map. I've used it before with the FAA Airport Layout Plan workspace, but I need to get set up my own. I viewed a few of the videos on Bentley Learn, but I need to set up a my workspace from scratch.
Does anyone have any links to get me started?
Dan
Hi Dan, You're best bet is to watch the videos in the Special Interest Group for Bentley Map: https://learn.bentley.com/app/Public/ViewLearningPathDetails?lpId=109171
Specifically the one that's titled "2016-01 (January) Bentley Map SIG - Introduction to Bentley Map Geospatial Administrator (SELECTseries 4)"
And this article might be a good starting point as well: https://communities.bentley.com/products/geospatial/desktop/w/geospatial_desktop__wiki/37088/--create-a-new-schema-recommended-workflow
Hope that's enough to get you going.
