Error message "default SHX font(s) in Bentley Map v8i
I get this error message when I hit 'Run' in Bentley Geospatial Administrator. How do I fix this problem?
"Cannot locate default SHX font(s) (defined as 'msdefault'). Please ensure that one can be found in MS_FONTPATH or MS_DWGFONTPATH, or modify the font configuration file to specify a different default. Program must now exit!"
Am I supposed to fix this in Geospatial Administrator.
Dan
