Can you explain me how to prepare a Deployment Image for the Connect version?
Hello Jerzy.
you may find more details in help file here: https://docs.bentley.com/LiveContent/content/en/Bentley%20Map%20Help-v3/GUID-8CF58AA7-93C6-497A-B74F-C39E85B778B9I hope that helps.Sebastien Lefrancois
Hi Sebastian,
thank you for your help..I know this procedure because it is the same in case of Microstation software. Now when you are downloading the Map software you are downloading a small instalation program only. This program install all instatlation files on the computer directly from the internet. It means that can't run preparing of Deployment Image beacause there is'nt exist the file of instalation archive which would contain neccesary files. It is also possible that I can't find this archive file (the Bentley Map setup executable).Do you have any diferent idea or can you point me name of this executable/instalation file?
Hello. Here on my (complete) image destination folder, the installation file name is "Setup_BentleyMapx64_10.00.00.030.exe".
Regards,Sebastien Lefrancois
Answer Verified By: Dan Weston
Thank you! It was very useful a piece of information. You have helped me to solve the problem.
I just went through this process and the link directly to the "To Create a Deployment Image" page in the README is: https://docs.bentley.com/LiveContent/web/Bentley%20Map%20Help-v6/en/GUID-F0888F0A-6208-4C74-A5BA-7925A911D458.html
