Grids and Graticule in Map.
Need help on using Grids and Graticule in Map.  Is there a tutorial?
  • I looked in the Bentley LEARN Content and did not see a tutorial for Grids & Graticules.  Are you stuck on any particular piece of the functionality?  Maybe we could step you through the Wizard to create them if so.
    The HELP file explains the settings for each Definition and Instance (chapter attached here for your reference).
    First create a Definition, then build the Instance for a particular Map.  The Definition specifies things like the Coordinate System, Units, Intervals, Grid Lines, Tick Marks, & Labels.  The Instance controls the X, Y extents, as-well as the Neat Line, Frames, and Symbology.
    Sometimes it is best to run through the Wizard steps, review the output, and refine the settings to suit your needs.  Some 'tweaking' is almost always done to get it just right.
