Hello Experts,
I am getting error while posting a feature in Bentley Map using Oracle database.
"Error Inserting Feature (Class : LayerName, id : 1234)
InsertRow:
ORA20012: need to be on latest version to insert
ORA-06512: at WMSYS,WM_ERROR, line 497,
ORA-04088 : error during execution of trigger 'WMSYS.WM$211INSERT'
The table is workspace enabled with history table.
Table registered through Geospatial Administrator.
Any help on how to resolve this issue ?
Thanks in advance,
A J
Bentley Version : Bentley Map Enterprise Series V8i (Select Series 4)
A J, This error doesn't sound familiar to us. Are you working in a LIVE workspace? Have you made modifications to the queried data, then tried Posting the feature? You should consider opening a Service Request so that the Support group can take a look at the issue to help troubleshoot the problem.
Hi Dan,
Thanks for the reply.
Are you working in a LIVE workspace? - Yes, Both Live and child version tried, issue appearing in both.
Have you made modifications to the queried data, then tried Posting the feature? - Yes
While enabling versioning using DBMS_WM.EnableVersioning command I mentioned "WO_OVERWRITE" option.
Error occurs only when i post through Bentley Map. Able to successfully post through SQL Developer.
If i am enabling versioning without this "WO_OVERWRITE" option, i can post without issue. But then no History view..
Are all of the Versions posted? is there a child version that needs to be posted? That may be holding Map back from posting.
Yes everything in Live version, except current edits which are in a child version, posting to it throws error.
Thank you for logging an SR for this issue. We are currently looking into this and will correspond with you via the SR.
