I'm stuck again...
OK I've got the combobox to filter out according to another comboboxs property and it works great....
However when the user goes to edit the feature again I cannot set the value of the operation combobox to the value of a feature property.....
I have this set at the moment Operation: CadPrimary, Property: TenureTypeFilter, I have an editing key of value type featureProperty with a value of "cadPrimary:TENURE_TYPE", which I would have thought upon editing a cadPrimary feature it would set the Operation combobox to the TENURE_TYPE of the feature and therefore set in motion the various criteria I've set for the the LMSID_LINK as it does when placing or after selecting it from the TenureTypeFilter combobox list (I simply want it to happen automatically as the user edits the feature.....)?
Cheers
Adam J
Hello Adam,
Can you post your XFM schema and database?
Chris
I haven't been able to get back onto the administration side of Bentley Map.
Perhaps this is a clearer question...
Upon editing a feature can you set an Operation property to a Feature Properties value?
There are a few examples of setting an Operation property to a Feature Property value (or based on the feature property value) after editing the feature property value in geo_example schema delivered with Bentley Map.
