[BM CE U1] Ribbon change request / enhancement
can be Bentley Map ribbon modified a bit?
  • I think Import/export tool should be available in Interoperability tab, not only in Home.
  • Can be not currently functional tool dimmed? I guess ribbon has this functionality (enable / disable tool). E.g. when no active data source (Oracle, SQL Server, WFS...) is attached, related tools (Edit, Remove) should be disabled. The same for Refresh Domain List and Version tools that are valid for Oracle only.
Also terminology would be standardized a bit more, otherwise it's confusing for users:
  • When data source is attached and a user tries to attach another one, the message is "Already connected to another storage, please disconnect first.".
  • But there is no Disconnect tool, only Remove.
  • ... it has to be the same, Disconnect as the tool name or remove connection in any message.
With regards,
  Jan
