Problems exporting to ESRI GDB or Shapefile
I work with DGN files with MSLINKS that I would like convert into SQL server spatial. I am using the recommended workflow where the DGN files are export to ESRI Geodatabase (GDB) and converted to SQL server using FME.
However I am already experiencing problems when exporting the data to ESRI GDB. I have tried with just a few features but get same type of error. I experience the same problem even if I try to export new features.
If I choose to export by right-click on the ESRI GDB file I get this error,
If I choose to export by right-click on a single feature I get this error,
I am using the Bentley Map SS4 (08.11.09.882).
Is there something I need to have installed to be able to export to ESRI GDB?
Thanks.
BR
Jens
