Mscatalog error
Has anyone come across this error?
No MSCATALOG table exists. Attachments of database data to graphical elements will not be possible. To create an MSCATALOG table, go to Settings-Database-Setup.
Which then I go to "Settings - Database- Setup"
There is no MSCATALOG table. Create one now?
Ok
Unable to update MSCATALOG table
There is a mscatalog table set up.
We have reloaded Bentley Map SS4 (Windows 10) and also reconfigured the ODBC setup. The ODBC is listed under the machine data source.
The other computers have the same setup with no errors.
