Hello
Why when I click Raster Manager - File - Atach - Raster, it does not open the next window to choose the images (.tif or .ecw), and it simply locks my computer, I can not click on anything else, I have to use the task manager to force the closing microstation.Someone knows what is happening to not open the window of the images and lock everything?I've reinstalled the program, created another file, rebooted the computer but it looks like it's something from the microstation.
thank you
Is this situation happened before to you? Have you tried to uninstall and reinstall Microstation V8i?
Bruneau
This problem started last week, before it was working normal.I already did all thisAnd the microstation of a friend from another company is also experiencing this problem
Did you have a Windows update by then? By the way are you using Windows 10 or 7?
Yes, it is up to date and I use the windowns 7
Can you send your DGN File and Raster Image, so we can test it. Use the SR to send your data.
