Map Enterprise SS4 running on WIndows 10 and Oracle 12c running on Solaris Operating System (SPARC 64-bit)
Running:
Oracle Database 12c Enterprise Edition Release 12.2.0.1.0 - 64 bit Production
Bentley Map Enterprise V8i (SS4)  Version 08.11.09.862
Existing Oracle DB moved from a Windows server to a Solaris server.  I updated the tnsnames.ora with new information and tested the connection in the GSA from one of our Map projects, connection successful.  Unfortunately, when I try to register updated table properties or add new Oracle tables to the project (as I had done prior to DB move) it doesn't find any tables and wants to remove the tables that are already registered and still exist in the DB.  Using the same project in Bentley Map (which I updated in the GSA to use the connection to the new DB), I am able to connect to the new Oracle DB  via Map Interoperability utility, Oracle tables are found and I can post data to the Oracle tables.
At this point, I can in the GSA update existing projects with the new Oracle connection information, save and export. These updated projects work correctly in Bentley Map SS4; no Oracle connection issues.  I just can't register additional tables or update table information with the GSA.
If anyone knows of an issue with this combination of Map, Oracle and OS, your information would be greatly appreciated.
