I need a bit of help) I have DWG file with points- each one has x,y,z. I need to print out a map where will be shown Z factor instead of point number. Where to change settings that Z will be shown?
Picture below was made in 3 D win program. I want to do a similar one in Bentley
Thanks for response. This tool works very well. But didnt found possibility to place just "Z". It goes all togetger- XYZ or YXZ just.
If you type the following command in the key-in window before you run the tool only the Z value will be displayed:
LABEL HIDEXY ON/Krister
Owner consultant at Surell Consulting AB
As Krister mentioned, just use the label command.
https://communities.bentley.com/communities/other_communities/askinga/w/askinga/450/label-only-the-z-with-label-coordinates-tool
