[BM CE U2] GSA exception for V8i project
I assume it's similar issue discussed already for Update 1, but because found in the new version, I am creating new post.
When I tried to publish V8i project from GSA CE U2, this exception is reported and nothing is exported.
Based on testing it seems a source of the problem is Reference File Index used in V8i project. When deleted manually in GSA V8i and upgraded to CE project later, the publishing seems work fine.
With regards,
  Jan
