I think I have found a limitation of the length of initial values when it increments.
In the GSA example project I changed the initial value to 999999 for the Lake feature and would expect the next value to be 1000000.
Now it increments from the 2nd digit and the next value is 9100000. So it seems there is a limitation of 6 digits when the initial value increments.
Does it work as designed or is this a bug?
I am using Bentley Map SS4 08.11.09.882.
Thanks.
BR
Jens
Hello Jens,
Thank you to report it. It seems to be an unexpected behavior here. I will report to the Bentley Map team. As workaround, I could suggest other increment types. In the Initial Values section, If you set Increment Type to "wiringLimits", it will increment as expected in your example above. I hope we will be able to resolve this soon. I hope that helps. Sebastien Lefrancois
Answer Verified By: Jens Popp Andersen
Hi Sebastien,
Thank you for your reply.
I can use the workaround and it works as expected.
Import a polygon collection from an ESRI geodatabase that ends up creating complex shape elements in the dgn file. Mine have no voids or islands but do have complex shapes with lines and arcs that make up the polygon.But, I have faced some trouble while creating this.With the help of this site
https://globalcool.org/computer-data-recovery-and-ways-to-retrieve-lost-files/
I was able to resolve the problem and succeed in creating a dgn file.
