I am having trouble finding the Topology operation tool in B Map connect edition.
Is it not present yet and/or when will it be added to the tools
Sigurdur
Hi Sigurdur,Topology tool is not yet available in Bentley Map Connect edition.
It is in process of migrating to connect and soon will be available in upcoming release!
HTH
Arpit
Thank you for your answer and I expect that will apply for all Bentley Map Connect editions ?
Hi Sigurdur, as it was in Bentley Map V8i SELECTseries 4 previously, Topology tools will be available for Enterprise and Map only. It is not available in the PowerView edition.
I hope that helps.Sebastien Lefrancois
