[BE CE U2] Data quality (topology) check: Overlapping polygons
is there any recommendation how to check data for overlapping polygons?
The data are structured in such way there are several levels with polygons only (when not, it's an issue but can be detected easily) where the overlap is not allowed, both in the same level (which is not supported by overlap analysis I guess) and also between levels. In fact it leads to check "every polygon feature with any other from the same or another level".
Is it possible? It looks to me it belongs to basic data quality checks, but I was not able to find how to do it easily in BM.
With regards,
  Jan
