I have created some features in BGA with the standard placement and edit dialogs.
When creating new features the textbox values are filled out with the values from the previous feature created.
This happens only in the same session.
However is it possible to avoid this and get a clean and empty dialog every time a new feature is created?
BR
Jens
Greetings Jens,
In the Bentley Geospatial Administrator, you should be able to use the "Store Last Value" setting of "None" for each business property (e.g. text box etc...) you wish to achieve that for.
Jeff Bielefeld [Bentley]
Hi Jeff,
That was exactly the setting I needed. Problem solved.
Thank you.
