We are upgrading from BM for MicroStation SS2 to SS4 using Oracle Spatial.
We have line feature (Textstege_Line) with two point sub features (Textstege_Text, Textstege_Cell).
When we register them i SS2 we are asked to add Id Generators for both sub-features (which we have). In SS4 we are only asked to add Id Generators for the main features.This result in the primary ID column for the sub-features are listed as a property. We can read Everything just fine, but the features cannot be posted back in SS4.
The primary and foreign key is defined as follows for the sub-features:
alter table TEXTSTEGE_TEXT add constraint TEXTSTEGE_TEXT_PK primary key (ID);
alter table TEXTSTEGE_TEXT add constraint TEXTSTEGE_TEXT_FK foreign key (TEXTSTEGE_ID) references TEXTSTEGE_LINE(ID) on delete Cascade;
Hi again Krister. We have identified an issue that popped up in a few SS4 builds. This will be resolved in an upcoming V8i release. Also, feature registration with sub-features works as expected in the CONNECT releases of Map as well. Thanks for pointing this out to us.
