can ı make the objects same size , because some are little some are bigger then other but all of them in some level and same thing. thank you for your help.
can ı make the objects same size , because some are little some are bigger than other but all of them in some level and same thnig.
  • Hi Serhat.  It's difficult to tell from your image if you used named text styles or not.  If you did, then use Match Text Attributes, select the style you want to apply to the other text. Then choose Change Text Attributes, turn on Text Style and select the text to change.   If you only want to change the size,  then just turn on the Height and Width as shown in this video:
    Best Regards,
    ~Inga
    Pick the tool.  Adjust the settings. Follow the prompts.
    Answer Verified By: Sebastien.Lefrancois
