New and Changed in OpenCities Map CONNECT Edition Update 3
Seems BM U3 is about to be released -https://docs.bentley.com/LiveContent/web/Bentley%20Map%20Help-v6/en/GUID-FCC7CFCD-2425-4436-AB82-7BEE440F33CD.html
  • Make Active for Edit now takes advantage of MicroStation's in-place editing for attached references. This change enables you to use the Activate and Deactivate options via the Reference dialog.
  • A Map Topology workflow has been added which contains Topology Cleanup and Topology Creation tools.
  • FME from Safe Software can now be used to import other formats into Map and Map Enterprise editions. Access FME from the Import or Export categories found in the backstage.
  • The Map Modeling workflow contains 3D Smart Editing and Textures tools.
  • The Help file erroneously mentioned that 3D Textures is included in UP3.  This is not the case.  Our apologies for this misinformation.
    Best Regards,
    ~Inga
    Pick the tool.  Adjust the settings. Follow the prompts.
