[BM SS4] Drop Polygon Collection crash
I need to drop Polygon Collections so they can be clipped (Application elements checked).
This works if I use plain MicroStation or Bentley Map without an active Project.
When I try to drop the elements when I run my BM Workspace MicroStation will crash and hangs.
Any ideas?
A small test file is attached.
Prior to this I've exported the file and selected to remove all XFM data in the Option dialog.
/Krister
Polygon_Collection.dgn
