CadScript to Bentley Map/Opencities upgrade-Advanced Map Finishing Tools
We are having to upgrade from CadScript and we need the Advanced Map finishing tools to do our job of getting pdf or ps output for printing. We have not been told whether we can install Bentley Map/Opencities for Select Series 2,3 or4 or have to go to Connect which I have been told does not include Advanced Map Finishing tools. We are currently running MicroStation V8i Select Series 2(08.11.07.443)
Can anyone tell me if they are using Advanced Map Finishing tools and in what version ?
Thanks.
  • This has been a great discussion about the need for specific CADscript and Advanced Map Finishing tools to be available, thank you for that.  If you can think of other commands please list them and we will make sure the Product Management teams know this in order to evaluate and plan for them in the future.
    I wanted to clear-up some confusion about the Support Policy --the licenses for the older products remain valid & will still initialize the software even though Support is discontinued, it's the Support Services for those products that are being reduced or expired.  Be sure to maintain the license details and installation packages, as the ability to download earlier versions is one important element that will not be available should you need to reinstall them.  The Support Services block illustrates which of these services will and will not be available.  https://www.bentley.com/en/desktop-applications
  • Hi Dan, Thanks for the reply. So let me get this straight. We will still be able to use CadScript after 1 July 2019 just with no support ? We have been told CadScript will no longer be available after that date. As you can imagine this is very worrying as we have no alternative at this point for producing finished map pdfs. My IT manager will be very interested to hear this new development.
  • You will still be able to use it after that date. The ability to download the install package for new installations will be unavailable. Download the install package now and save it on a server drive someplace. Then you will be able to reinstall it after the support officially ends.
    I don't know how your company works, but there are many that do no allow users to run unsupported versions of software. If your company is that way you're kind of stuck.
    Rod Wing
    Senior Systems Analyst
  • Hi Rod, What about licensing ? How does that work. I do not do the installing and licensing that is down to IT Dept. Does CadScript work with Select Series 4 That would buy us some more time. Thanks.
  • As already mentioned, the license will still work.  It's just that the product is no longer supported.  As well, please note that in OpenCities Map SELECTseries 4, you will use the Map Finishing tools which are included in the product.  These are the old CADscript tools.  To access these tools, please open your DGN in the msgeo_mapfinishing workspace.  The image below shows the Map Finishing toolset compared to CADscript.
