We are having to upgrade from CadScript and we need the Advanced Map finishing tools to do our job of getting pdf or ps output for printing. We have not been told whether we can install Bentley Map/Opencities for Select Series 2,3 or4 or have to go to Connect which I have been told does not include Advanced Map Finishing tools. We are currently running MicroStation V8i Select Series 2(08.11.07.443)
Can anyone tell me if they are using Advanced Map Finishing tools and in what version ?
Thanks.
Hi Inga, Thanks for all of your help !!
You're welcome.
Map finishing tools doesn't seem to be available in Bentley Map SS10?
The Map Finishing tools are available in Bentley Map V8i (SELECTseries 10). Access the program from the Start Menu, in the Bentley group:
If the program is not in your Start Menu, you should uninstall previous versions of Bentley Map and Install Map V8i (SELECTseries 10) again.
Select series 10 ?? We are on SS4 and were told we couldn't have Connect to get Map Finishing Tools so we stayed with Select Series, where did SS10 come from ? Thanks.
