postgis/postgres 8
According to the Map README details, Map supports version 10.4/2.4:
Are you trying a connection that is not working? or are you asking for future reference?
I'm trying to connect to a postgis database.
I think PostgreSQL Version 8.2.
I succed the connection but it don't showm the tables
It's not clear how you are connecting to PostgreSQL and what you expect to see.
PostgreSQL (PostGIS) is a method of storing geometry and properties in spatial tables in a similar fashion to Oracle Spatial and SQL Server. To connect to a spatial database, you need to create a graphical source via the Geospatial Administrator
If your spatial tables are set up correctly, they will be recognized as features that can be registered. To do that, choose Register Features from the right click menu and follow the Register Features wizard.
Registered features are added to All Users > Features node for further customization:
For more information on working with spatial databases, please refer to:
Working with Spatial Databases
Thaks booth
Indeed I have published it twice. Sorry I'm rooky.
It appears that it works only with PostgreSQL Version 10.4 and PostGIS version 2.4
