Can someone in the community throw light on upgrading to Open Cities Map Enterprise from Bentley Map Enterprise SS4 or Bentley Map Enterprise CONNECT Edition?
If am on Bentley SELECT Subscription for Bentley Map Enterprise, am I eligible for a free upgrade to Open Cities Map Enterprise?
I remember when Bentley Map was launched, MicroStation GeoGraphics users with SELECT had to pay an upgrade fee to upgrade to Bentley Map (if I am correct!)
I noticed on the Bentley Support Status page:
https://select.bentley.com/FulfillmentCenter/checksupportstatus
that Open Cities Map support will expire on 01-July-2019 and will be discontinued on 01-Jan-2021.
Does that mean that 01-Jan-2021 will be the end of Bentley Map/ Open Cities Map Geospatial Desktop product range from Bentley?
Tx
SRG
The CONNECT Edition FAQ discusses upgrade options:
There are three possibilities to upgrade from V8i to CONNECT Edition:
1. If you own Bentley Map PowerView V8i or Bentley Map V8i or Bentley Map Enterprise V8i:
2. If you own MicroStation V8i and Bentley Map for MicroStation V8i you have two choices:
3. If you own MicroStation V8i and want to purchase Bentley Map for MicroStation V8i:
As you noted, support for the V8i product line will be discontinued January 01, 2021, but this does not imply the end of the OpenCities Map CONNECT Edition products. (Map PowerView, Map and Map Enterprise).
