I'm using the latest Bentley Connect edition of Map and my "Command Manager" box keeps detaching from the side dock and maximising to the full screen. Every time I try to minimise it to dock, it resizes itself to full size.
from this (full screen), to this Docks itself to the bottom of the window
I've tried multiple times to resize, re-dock and it keeps doing it.
Any assistance would help thanks.
Sue Crump said:I'm using the latest Bentley Connect edition of Map
A better place to post your question would be the Bentley Map Forum. Use this Forum's More|Move button to move your post to a different Forum.
Hi Sue,
Please read and follow communities best practices and always specify product name and its version:
Sue Crump said:keeps detaching from the side dock and maximising to the full screen.
I have not the latest OpenCities Map CE Update 3 installed yet, but it's true that Command Manager dialog is unpredictible in some situations (especially docking).
Sue Crump said:Any assistance would help thanks.
When I have had a problem with strangely docking Commnad Manager, usually the solution is to undock it, resize to quite small size and dock it again.
You can also try to delete upf file and docking xml file(s), which is often recommended solution for all power products when they start behave strangely.
With regards,
Jan
As I said, I resize the window smaller, and it resizes itself to full size every time I attempt to dock it. 'll try the other options.
