<?xml version="1.0" encoding="UTF-8" ?>
<?xml-stylesheet type="text/xsl" href="https://communities.bentley.com/cfs-file/__key/system/syndication/rss.xsl" media="screen"?><rss version="2.0" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:slash="http://purl.org/rss/1.0/modules/slash/" xmlns:wfw="http://wellformedweb.org/CommentAPI/"><channel><title>Can I redirect an Open Cities Map configuration directly to a network location?</title><link>https://communities.bentley.com/products/geospatial/desktop/f/bentley-map-forum/179973/can-i-redirect-an-open-cities-map-configuration-directly-to-a-network-location</link><description>I am using Open Cities Geospatial Administrator to create Open Cities Map projects. I want to locate the project workspace and workset on a network location. The Workspaces Root Directory field offers me the solution to do so, but the &amp;lt;workspacename&amp;gt;</description><dc:language>en-US</dc:language><generator>Telligent Community 12</generator><item><title>RE: Can I redirect an Open Cities Map configuration directly to a network location?</title><link>https://communities.bentley.com/thread/523618?ContentTypeID=1</link><pubDate>Thu, 23 May 2019 19:47:27 GMT</pubDate><guid isPermaLink="false">6dad98f5-dbc9-4c4d-a9ba-e9da8dc6aa8e:6d972d42-c77c-4530-a5f5-50e0eb837f4f</guid><dc:creator>Dan Weston</dc:creator><description>&lt;p&gt;The easiest way to do this is to install Map on the local machines, then copy the installed workspace components onto the server.&amp;nbsp;&lt;/p&gt;
&lt;p&gt;It may be easier to grab the entire /workspace/ folder from the local machine and copy it to the server.&amp;nbsp; This will include the items installed with Bentley Map.&amp;nbsp;&lt;/p&gt;
&lt;p&gt;Use the Geospatial Administrator&amp;#39;s Workspace Root Directory to point to the new (network) location, as you have done.&lt;/p&gt;
&lt;p&gt;&lt;img alt=" " src="/resized-image/__size/320x240/__key/communityserver-discussions-components-files/5924/GSA-Workspace-root.png" /&gt;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item></channel></rss>
