I would like to force the format of a value in the placement and editing dialog in Map. The restriction would be nnn-nn 3 digits a dash then 2 digits. Is this possible? The property type is character because the dash is part of the stored value.
Thad
I've created the following wiki article and example schemas that describes how to do this.
- Concatenate properties to populate new property using Property Watcher
Answer Verified By: Dan Weston
