Hello, I have got a problem, and I haven't found any tools in Bentley Map system for this problem. The problem: I want to insert an existing dgn file into an XFM project. Dgn file is connected to a database (MS Access). I would like to connect one of the fields of the database with a feature of the XFM project, like PBA value: For example: connect Lot Feature with LotID of database like PBA value. I defined the Lot Feature in the Geospatial Administrator according to next figure. Thank you for your help.
Ica
Keith Raymond
Thank you
