Unable to import WFS. It returns error 401. On the same machine QGIS attaches it correctly.
Not yet. I pick a WFS tool and not able to follow the prompts. The service provider will file a Service ticket.
Thank you for reporting the issue. We are able to connect and query all features by using the following URL:
http://services.lgia.gov.lv/arcfree/services/GIOLAND_LV/CLC2012_LV_WFS/MapServer/WFSServer?version=1.1.0
Any workaround?
The recommended workaround is to use the following URL. It works fine at our end and allows us to connect as well as query 56490 features. I tested V8i SS10 as well as CONNECT Edition. Hopefully that will allow you to connect and use the dataset as well. Thanks for your patience while we investigated.
Which authentications Bentley Map supports? Can it use Oauth?
