Using OpenCities Map Enterprise Update 3 and OpenRoads Designer 2018 R4.
I am trying to export civil alignment and the alignment shows up at other show up as Other Elements and export the alignment as points.
Any clues on how OCM can recognize the alignment as a poly line?
Hi Juan,
We identified this as an issue earlier on and found that using some of the MicroStation Manipulation tools (Drop, etc) can help. Please open a New Service Request so that we can get your DGN File and test some scenarios on our systems.
