It doesnt look like Bentley MAP PowerView supports the Bing Maps raster attach.Is there a way to use Bing Maps in PowerView?
Hi Loren.
Bing Maps in PowerView will be available in the next update 4. This new PowerView update 4 should be available soon. See link below for a new way in Connect Edition to enable Bing Map from View attribute. https://communities.bentley.com/products/geospatial/desktop/w/geospatial_desktop__wiki/27148/--bing-maps
I hope that helps.
Sebastien
New OpenCities Map PowerView Connect Edition - Update 4 is available now. https://softwaredownloads.bentley.com/en/ProductDetails/1940Sebastien
Hi Sebastien,
Sebastien Lefrancois said:New OpenCities Map PowerView Connect Edition - Update 4 is available now.
thanks for the information. I do not see any announcement the new version has been released :-(
Jan
I can confirm that the Bing Map Background Map option is available in Map PowerView CONNECT Update 4
Is it also slow as it is in OpenCities Map U4?
