is there a way to see your ACS position as well as the UTM coordinates in the element information dialogue? I can currently only see UTM even though I am working with an active ACS and can see the cursors ACS position on the bottom of the screen; however when I select an element (a circle) I would like to know its ACS position and I can't figure out how to see this. Any suggestions?
