Good morning,
After installing Microstation Connect Edition, the i-models that I publish don't display the references anymore, although there are embedded into the i-model. What may be the issue?
Thank you!
Olivia
in addition to to Jon's question, please provide also information about:
With regards,
Jan
I have MicroStation CONNECT Version 10.12.00.40. The referenced i-model version is 1.5
Thanks for the details.
Can you describe used workflow to explain where the problem is. It's not quite clear, because in the subject you mentioned Bentley Map Mobile, where I guess it's expected Bentley Map (OpenCities Map) will be used (together with Bentley Map Mobile Publisher in V8i).
BTW What version of Bentley Map Mobile do you use? And on what platform?
Special UtilityProgram said:After installing Microstation Connect Edition
It evokes it worked in the past. In what version?
Special UtilityProgram said:After installing Microstation Connect Edition, the i-models that I publish don't display the references anymore
Do you mean the references are not displayed in MicroStation when i-model is opened / referenced or when you open the same i-model in Bentley Map Mobile.
Special UtilityProgram said:although there are embedded into the i-model.
Are you sure? Can you check it using another software?
Special UtilityProgram said:What may be the issue?
At first, let's reconstruct and describe the whole workflow (a chain) how i-model is created and consumed.
If the problem is in Bentley Map Mobile and not in MicroStation, I recommend to move this discussion to Geospatial Desktop forum. To move the post, use More > Move tool under your first post.
