RE: [MicroStation Forum] Bentley Map Mobile - i-Model reference issue
For office work, we use MicroStation CONNECT. But for field work, we use Bentley Map Mobile.
So in order for the inspector on the field to mark up his redlines, I publish an i-model in MicroStation which is then opened in Bentley Map (version 05.05.08.06).
Before using MicroStation CONNECT, I was using MicroStation V8i. But I need MicroStation CONNECT to be able to open the .markupdb (the redline file coming from Bentley Map Mobile). So since I installed MicroStation CONNECT, the i-model files that I create don’t show the references. I can tell they are there by checking in Bentley Map, but I can’t see them in Bentley Map, or in MicroStation. In Bentley Map I open the i-model, in MicroStation I attach it as a reference. If I merge the reference, I can see all the details. But I would like to keep the file as reference.
I tried to move this conversation to Geospatial, but I failed. If you can, please move it.
Thank you!
From: Jan Šlegr <bounce-FF247D2F-7ED5-451A-B5B2-A6FC5DBBF405@communities.bentley.com>
Sent: 17-Oct-19 12:46 PM
To: MicroStationForum@communities.bentley.com
Subject: RE: [MicroStation Forum] Bentley Map Mobile - i-Model reference issue
Thanks for the details.
Can you describe used workflow to explain where the problem is. It's not quite clear, because in the subject you mentioned Bentley Map Mobile, where I guess it's expected Bentley Map (OpenCities Map) will be used (together with Bentley Map Mobile Publisher in V8i).
BTW What version of Bentley Map Mobile do you use? And on what platform?
After installing Microstation Connect Edition
It evokes it worked in the past. In what version?
After installing Microstation Connect Edition, the i-models that I publish don't display the references anymore
Do you mean the references are not displayed in MicroStation when i-model is opened / referenced or when you open the same i-model in Bentley Map Mobile.
although there are embedded into the i-model.
Are you sure? Can you check it using another software?
What may be the issue?
At first, let's reconstruct and describe the whole workflow (a chain) how i-model is created and consumed.
If the problem is in Bentley Map Mobile and not in MicroStation, I recommend to move this discussion to Geospatial Desktop forum. To move the post, use More > Move tool under your first post.
With regards,
  Jan
View online
You received this notification because you subscribed to the forum.  To unsubscribe from only this thread, go here.
Flag this post as spam/abuse.
Parents Reply Children
