We have created some test imodel files and can see the thumbnails on Ipad but when trying to open them I get "No Views Found" "This model does not contain any saved views."
Richard,
Which iPad app are you using and what was used to publish the .imodel file?
Jeff Bielefeld [Bentley]
Hi Richard,
what product and version did you use to publish i-model? Also, is your source design file (model) 2D or 3D?
Using you very limited information, it's hard to guess what is wrong.
With regards,
Jan
Published from Bentley Comms V8i select series 4. It is 2d.
I am just a CPV user, it was published by a design engineer.
Using map mobile on Ipad.
Thank you
Richard Hebda said:It is 2d.
I am not sure, but I think this is the problem ... I remember it was not possible to publish 2D models, it's expected (I do not understand why) everything is 3D. Or was it that it's possible to publish but not display? I only remember whan I tried publishing workflow some time ago, there was a problem with data dimensions ... and I do not recall any information from Bentley it has been solved.
Use of Bentley Map Mobile Publisher or the Bentley Map Mobile Converter are required to produce 2D or 3D i-models for Bentley Map Mobile use.
