long time no see...
I have a question about one specific problem in Map Manager when I define classes for point elements (cells) and override native symbology with new one in Map Manager.
In dgn file you'll find few XFM features in four category: points (cells), lines, polygons and texts. When map definition is off cells are shown as it should be. In native symbology as is in cell library.
Then in Map Manager I want to show exactly the same cells with native symbology and depending to the attribute value (cpt). I have create classes and queries for that purpose with selective override only to override cell name. Nothing more. When map definition is tuned on, Map manager show cells depending on the "cpt" attribute (which is ok) and override colors of cells (which is not ok).
Am I still missing something or there is a bug in Map Manager?
Many thanks in advance!
Mladen Kolarek
Bentley OpenCities Map Update 4 (10.04.00.42), example file:
Example_MapManager_handling_cells.dgn
Hello Mladen,
I took a look at your file but would need the GSA Schema to fully test the issue. If you would file a New Service Request and attach the files we can investigate further.
Dear Dan,
thanks for the effort to resolve this issue.I have tried to start new request. Unfortunately, at the moment I don't have enough privileges to start a new service request on my account or there is something wrong with the service today. I'll contact account administrator to give me necessary privileges.
Until that I send GSA schema in this replay. I would kindly ask you to analyse schema and dgn file in original post, in order to see if there is a bug or I'm doing something wrong.
Many thanks in advance.
GSA_Example.zip
Service request posted under track number 7001000944.
