I am updating a city map try ortofotogrammetry right now. Need to update buildings a lot. So I know how to draw a new rectangular object or move one side of the building to some distance, but usually terraces and others starts from the midle of the building.
I am using Stella Map
Get to know AccuDraw and the Snaps tools.
- Drawing Aids tab: https://docs.bentley.com/LiveContent/web/MicroStation%20Help-v15/en/GUID-B9C68C4C-182E-4781-9D5F-C481F0F7D88F.html
- SmartLine with MicroStation: https://learn.bentley.com/app/Public/ViewLearningPathDetails?lpId=111010
- AccuDraw Rocks! https://communities.bentley.com/communities/other_communities/askinga/w/askinga/1979/accudraw-rocks
It was very useful for me. Thank you Dan. But still need advice. Look this short video: lupinet-my.sharepoint.com/.../EVGq_JsYNMpItg5dMUYgu0YBLEfO44cHT8GHump-ovl0ZA
How to start lines drawing from the second moved already Accudraw point?
If I understand correctly, it may benefit by first using the Place Point or Insert Vertex command at the position on the line you would like to start the second line.
The new lines are partially obscured by the image - ensure that the image is on the Background Plane, and that it's elevation is zero (az=0). Since you are working in a 3D file, it would be beneficial to draw your buildings and terraces at their true depth, also using AccuDraw and the AZ= command (in a Top View).
Hi. I mean that I need to start drawing this buildings part from point that you mentioned in your image. But I cant figure out how to use Accudraw that I start to draw from there. Now I suppose to do like this: lupinet-my.sharepoint.com/.../EWffE-OSliNJgyxgBm6RhPYBQqJif4gUrEygew2DCW6Tig
