Hi
I know that I can in the configuration files choose to not have the Automatic Geometry properties, but can I somehow turn them off when the designfile is loaded
Erik Wirring
LE34
Denmark
Hi Erik.
The configuration variable is the only way to disable this function. You can set this variable to your custom project, but also in the default worksets as msgeo (v8i) and WorkSet (Connect). In loaded design file, on Export or DataBrowser, geometric properties column could be unchecked to not display/use them. It exist no other way to disable this live in the DGN.
Other solution is to define MS_GEOXFM_DISABLE_GEOMETRIC_PROPERTIES variable as Windows System Environment Variable.
Regards,Sebastien Lefrancois
