using OpenCities Map 10.04.00.42, when I want to open PostgreSQL database, I receive this Exception:
The Property 'footprint' is null in ECInstance {gensmd_m3_cartographicmodel_data_table()} Bentley.ECObjects.ECObjectsException+NullValue: The Property 'footprint' is null in ECInstance {gensmd_m3_cartographicmodel_data_table()} v Bentley.ECObjects.Instance.NullPropertyValue.get_NativeValue() v Bentley.EngineeringContent.Storage.Xfm.addPropertiesToFeatureDef(opaquePointer* featureDef, Boolean isRootFeature, IECNamedValueContainer propertyValueCollection, IECNameMappingEntry classMapping, ECXfmSettings settingsObject, IDictionary applicationAttributes, Boolean createCollection, Boolean includeAll, IList`1 pkNames) v Bentley.EngineeringContent.Storage.Xfm.ECXfmSchemaSupport.XfmFeatureDefFromInstance(IECNamedValueContainer instance, IECNameMapping nameMapping, Char* rootFeatureName, ECXfmSettings settingsObject, IDictionary applicationAttributes, Boolean createCollection, Boolean includeAll, Boolean isRoundTrippable) v Bentley.EngineeringContent.Storage.Xfm.ECObjectToXfmWorkingStorage.GetOrAddFeatureDefinitionFromClass(IECClass classDef, Boolean keepInSession) v Bentley.Geospatial.MapQuery.MapConnectionManager.CopyRISDomainClasses(IECStorage destStorage, IEnumerable`1 classes, IStorageImportCriteria storageImportCriteria) v Bentley.Geospatial.MapQuery.MapConnectionManager.GDIConnectionOpened(Object sender, ConnectionEventArgs eventArgs) v System.EventHandler`1.Invoke(Object sender, TEventArgs e) v Bentley.Geospatial.DataInterchange.GeoDataInterchangeAddIn.OnConnectionOpened(IStorageImportCriteria storageImport) v Bentley.Geospatial.DataInterchange.GeoDataInterchangeAddIn.set_MasterFileImport(GDIImportCriteria value) v Bentley.Geospatial.DataInterchange.GDIExplorerConnectionsNode.AddNewNode(GDIExplorerModifyDataNode node) v Bentley.Geospatial.DataInterchange.GDIExplorerConnectionsNode.AddNewPostgisNode(PostgisConnectionInfo connectInfo, Boolean showNewConnectionDialog) v Bentley.Geospatial.DataInterchange.GDIExplorerAddIn.AddNode(Action`1 addAction) v Bentley.Geospatial.DataInterchange.GDIExplorerAddIn.ConnectPostgis(String unparsed) v Bentley.Geospatial.DataInterchange.GDIExplorerAddIn.ConnectPostgisCmd(String unparsed)
Because it's a result of some feature testing, it's not crucial, but I have two comments:
I have to say that how connection works in OCM is beaten by both ArcGIS and QGIS completely in terms of speed, intuitive workflow and friendliness. To display data requires more typing and from time to time exceptions are thrown without any further explanation, whereas it's expected it would by just point and click and drag and drop, maybe to enter user/password credentials, but nothing more.
With regards,
Jan
Hi Jan. I agree with you that a simpler error message should be presented. In this particular case I'm wondering if the footprint column might use a datatype that we haven't supported yet? Is it possible to get the definition of the table? That would help us understand the issue, replicate it and fix it. Thanks!
Hi Jan,
That exception was caused by an improvement to one of the APIs that Map depends upon. We've adapted to it, and the fix will be in Update 5. As for error messages being friendlier, that is an ongoing effort.
Cheers,
Elliott
Answer Verified By: Jan Šlegr
Hi Martin and Elliott,
thanks for your answers.
The database I tested is a part of bigger project, covered by NDA. But I think one minor table would not cause any problems ;-)
See CREATE script attached. I am aware it's not standard spatial table, but e.g. QGIS is able to analyze the table content properly and to work with all geometry data as with individual data sources.
-- Table: m3_cartographicmodel.data_table -- DROP TABLE m3_cartographicmodel.data_table; CREATE TABLE m3_cartographicmodel.data_table ( graphic_symbol text COLLATE pg_catalog."default", geom geometry(Geometry,5514), graphic_geom geometry(Geometry,5514), reference_geom geometry(Geometry,5514), source_id text COLLATE pg_catalog."default", is_visible boolean, status integer, generalization_cost integer, outline_color text COLLATE pg_catalog."default", footprint geometry(Geometry,5514), priority integer, id integer NOT NULL DEFAULT nextval('m3_cartographicmodel.data_table_id_seq'::regclass), place_priority integer, CONSTRAINT id_pkey PRIMARY KEY (id) ) WITH ( OIDS = FALSE ) TABLESPACE pg_default; ALTER TABLE m3_cartographicmodel.data_table OWNER to postgres; -- Index: data_table_geom_idx -- DROP INDEX m3_cartographicmodel.data_table_geom_idx; CREATE INDEX data_table_geom_idx ON m3_cartographicmodel.data_table USING gist (geom) TABLESPACE pg_default; -- Index: data_table_graphic_geom_idx -- DROP INDEX m3_cartographicmodel.data_table_graphic_geom_idx; CREATE INDEX data_table_graphic_geom_idx ON m3_cartographicmodel.data_table USING gist (graphic_geom) TABLESPACE pg_default; -- Index: data_table_place_priority_idx -- DROP INDEX m3_cartographicmodel.data_table_place_priority_idx; CREATE INDEX data_table_place_priority_idx ON m3_cartographicmodel.data_table USING btree (place_priority) TABLESPACE pg_default; -- Index: data_table_placesymbols_idx -- DROP INDEX m3_cartographicmodel.data_table_placesymbols_idx; CREATE INDEX data_table_placesymbols_idx ON m3_cartographicmodel.data_table USING btree (graphic_symbol COLLATE pg_catalog."default", status) TABLESPACE pg_default; -- Index: data_table_reference_geom_idx -- DROP INDEX m3_cartographicmodel.data_table_reference_geom_idx; CREATE INDEX data_table_reference_geom_idx ON m3_cartographicmodel.data_table USING gist (reference_geom) TABLESPACE pg_default;
