Hello.
There may be a similar question to this one elsewhere.
Does OpenCities Map have a statistics analyze tool of some kind for geospatial information?
For example, I have a map of water pipelines in my town. These pipelines vary in sizes and types and are categorized by areas. How can I ask Map to calculate total length of pipes by size, type and area?
Bjorn M. Arnason
Hello Bjorn,
We recommend using the Data Browser for your Thematic results, then Save as... CSV and perform the analysis in Excel.
And we all hope for a migration to Item Types (EC attributes) so we can use pure MicroStation reporting
/Krister
Owner consultant at Surell Consulting AB
@Krister, the Export MicroStation Elements command in the Map products now includes an Item Types check-box to retain the XFM Attributes as EC Attributes. This is available from the Map Manager's Layer List.
