Unable to import WFS data (GeoServer Version 2.2.3), got these errors:
WFS 2.0:
CE:
WFS Service encountered the following issue: java.lang.RuntimeException: Failed to get property: {http://www.opengis.net/wfs/2.0} boundedBy Failed to get property: {http://www.opengis.net/wfs/2.0} boundedBy java.io.IOException null Cannot do natural order without a primary key
V8i: WFS Service encountered the following issue: java.lang.RuntimeException: Failed to get property: {www.opengis.net/.../2.0}boundedBy Failed to g
WFS 1.1.0:
CONNECT
Exception: The operation has timed out System.Net.WebException: The operation has timed out at System.Net.HttpWebRequest.GetResponse() at Bentley.EngineeringContent.Storage.Wfs.IO.WebResource.IssueRequest() at Bentley.EngineeringContent.Storage.Wfs.Connection.WfsProxy.ExecuteOperation[ReturnType](WfsOperation`1 wfsOperation, ExecutionController executionController) at Bentley.EngineeringContent.Storage.Wfs.Query.WfsStorageQueryExecutor.RetrieveDatasets(IEnumerable`1 featureRequests, WfsProxy wfsProxy, ECCursorModifiers cursorModifiers, ExecutionController executionController) at Bentley.EngineeringContent.Storage.Wfs.Query.WfsStorageQueryExecutor.ExecuteGetFeatureOperation(IEnumerable`1 featureRequests, WfsStorageConnectionContext connectionContext, ECCursorModifiers cursorModifiers, ExecutionController executionController) at Bentley.EngineeringContent.Storage.Wfs.WfsStorage.ExecuteQuery(IECCriteria criteria, ECCursorModifiers modifiers, IExtendedParameters extendedParameters) at Bentley.Geospatial.DataInterchange.GDIImportProcessor.ImportStorageImport(IImportCriteria criteria, IStorageImportCriteria storageImport, Boolean cancellable) at Bentley.Geospatial.DataInterchange.GDIImportProcessor.Import(IImportCriteria importCrit, IStorageImportCriteria singleStorage)
v8i:WFS Service encountered the following issue: org.xml.sax.SAXException: Attempted to construct illegal filter - I dont understand the tag: gml:Polygon.
WFS 1.0.0:
CONNECT - also timeouts
v8i - Import Complete (3904 features in 5.086 seconds).
Thanks.
